Sold FS - Lots of stuff.
dah_hunter
got to sell some stuff thats lieing around. need to save up.
Alpine Type X in Custom Box - $300OBO
I still have original Box for Sub.
# Carbon fiber/aluminum honeycomb cone
# High-roll Santoprene rubber surround
# Cast aluminum frame
# Dual 4-ohm voice coils
# Frequency response 24-200 Hz
# Power range 500-1,000 watts RMS (500 watts per coil)
# Peak power handling 3,000 watts
# Sensitivity 81 dB
# Top-mount depth 8-5/8"
# Sealed box volume: 0.5-1.0 cubic feet
# Ported box volume: 0.6-1.5 cubic feet
PG TANTRUM 1200.1 - $300 obo
* Into 4 ohms @ 12.5 Vdc (IASCA/USAC): 250 x 1
* Into 4 ohms @ 14.4 Vdc: 1200 x 1
* Into 4 ohms @ 14.4 Vdc (Dynamic Power): 1400 x 1
* Recommended Fuse Size: 80 Amps
* Dimensions: 11.75L x 10.0W x 2.35H
* Frequency Response: ±3dB, 20Hz to 20kHz
* Signal to Noise Ratio (A-weighted): >95dB
* Input Sensitivity: 100 millivolts to 4 volts
* Crossover Frequency: 30Hz to 300Hz
* Subsonic Frequency: 5Hz to 50Hz
* Crossover Slopes: 18dB per Octave
* Bass Boost: 0 to +18dB @ 45Hz
* DC Input Voltage Range: 10 volts to 15.5 volts
* Operating Efficiency: >70%
* Typical Current Draw at Idle: 3 amps
* Minimum Load: 2 ohms
No Ends Caps..
CC-752 - $110
4 Ohm Stereo Power (RMS): 75W X 2
4 Ohm Bridged Power (RMS): 250W X 1
2 Ohm Stereo Power (RMS): 125W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
SoundStream Rubicon 204 - $100
4 Channal amp.
Not sure of the specs..
Eclipse 3520 - $70obo
2 Channel amp
30 X 2 AT 4 OHM OR MONO SUB LOW PASS @100 WATTS AT 4 OHM
Pioneer Shallow Mount 12"x2
in a unfinished Box. - $250obo
More info
12" Concept Dual Voice coil Sub - $100obo
Dont rember the specs.
2x 10" MTX 4000 Subs in a Box
$80obo
Pyramid 800 watt amp - $50
***New Stuff**
12W7 JLAudio
Eclipse CD5000 Deck..
$$400
dah_hunter
dah_hunter
Blaine, WA
BMW Sidewayz
