Sold FS .::. Lots of my Wire, Fuses, Install Kits etc.
RetroAudioinc
Custom Car Audio Decals
This is a lot of my Wire, Fuses, Install Kits etc.. I will have more listed tomorrow.. Thanks..
(1) Roll Light Gray Carpet for Speaker Boxes 12x10 local pickup only - $20
(1) Roll Black Carpet for Speaker Boxes 12x10 local pickup only - $20
(22) Street Wires 20 Amp SE Fuse - 4 pack - $5
(6) Street Wires 30 Amp SE Fuse - $5
(11) Gold Quest Power - Competition Gold - Pro SE Fuse Holder - $7
(12) Gold Quest Power - Competition Gold - 3SE Fuse Block (3 in, 3 out) - $12
(8) NEW Pyle Link Install Kits PLAM14 - 1000 Watts - 20' Amplifier Hookup Kit for Battery, Head Unit and Speakers - $10
* 20ft. 8 Gauge Red Power Wire
* 4ft. 8 Gauge Black ground Wire
* 20ft. 16 Gauge Blue Remote Turn-On
* 20ft. 12 Gauge Speaker Wire
* 20ft. RCA Audio Cable
* 6ft. Black Split loom Cable Conduit
* AGU Type 60A Gold Plated Fuse
* Water Resistant In-line Fuse Holder
* 2 Ring Terminals: 8G
* 2 Spade Terminals: 8G
* 5 Spade Terminals: 14-16G
* 3 Butt Connectors 20 Cable Ties
* 1 Black Grommet
(1) Gold Quest Power - Competition Gold - 125 Amp Gold Hi-Amp Fuse - ANL - $7
(1) Gold Quest Power - Competition Gold - 80 Amp Gold Hi-Amp Fuse - ANL - $7
(1) Gold Quest Power - Competition Gold - 100 Amp Gold Hi-Amp Fuse - ANL - $7
(2) Gold Quest Power - Competition Gold - 50 Amp Maxi Fuse - 2 pc. - $3
(1) Gold Quest Power - Competition Gold - 40 Amp Maxi Fuse - 2 pc. - $3
(2) Gold Quest Power - Competition Gold - 60 Amp Maxi Fuse - 2 pc. - $3
(1) Stinger 24 Karat Series - Gold Long Right Angle RCA Adaptor - $5
(2) Stinger 4-Way with 2 1/0 and 2 4/0 - $10
(1) Stinger SPV20 High Performance Dry Cell Battery - SOLD
(1) Kicker Wall Clock WORKS - $30
(2) Kicker L7 - Blown - $50 ( You can send these back to kicker and they will send you a new one, this years modle for $220 I think it was. I don't think you can recone these. )
I took a ton of photos today and here they are: Click here
If for some reason you can't seem to find the item your looking for just PM me and I will send you a direct link..
Please add shipping to all items from 32807
My paypal is bikepartsusa@hotmail.com
I think thats everything... If you have any questions just PM me...
free bump!
ive ran 3 hammer h1s for a few years in a demo truck for Tru, Onyx subs and Crystal mobile sound and other sponsors.
BADASS amps! Still got some Tru amps left over, holding onto them for a rainy day:)
GL on the sale, i dont think alot of people on here know about high end SQL class A/B sub amps. Trust me they sound WAAAYYYYYYY better and are totally underrated from their specs.
I have 4 TS-W3002D2's I am looking to sell or trade these are BNIB never been taken out or used in any way. I am open to trades so hit me with what you have in mind..
Price $289 plus shipping for 2 TS-W3002D2.
Price $130 plus shipping for 1 TS-W2502D2.
TS-W3002D2|D4
Premier 12" Champion Series PRO Subwoofer with 3500 Watts Max. (1000 Watts Nom.)
  • Interlaced Basalt/Carbon Fiber Reinforced IMPP Cone
  • Air Suspension System
  • Recommended Enclosure : 0.50 ~ 1.0 Cubic Feet
Introducing our new Premier® Champion Series PRO Subwoofers which feature an all-new design and look.
Both subwoofers have a maximum power output of 3500 watts. You now have a choice to select from either a Dual-Voice Coil 2-ohm or 4-ohm subwoofer:
  • TS-W3002D2: Dual 2 ohm, 4 Layer, Long Coil (1 ohm x or 4 ohm)
  • TS-W3002D4: Dual 4 ohm, 4 Layer, Long Coil (2 ohm x or 8 ohm)
The Premier TS-W3002D2/4 subwoofers are designed to produce enormously powerful music. Just take a look at its super-heavy-duty construction, all designed to handle up to 3,500 watts max. Double-stacked magnets for higher power, and a step-up radial surround for superior control and long excursions. We used a constructed cast-aluminum basket for this sub. Add in our patented IMPP cone and you've got a monster sub that can handle whatever you want to throw at it — including Pioneer's new breed of SPL amplifiers like the PRS-D1200SPL.
For its revolutionary 3.25 inch deep Shallow Subwoofer, Pioneer created an Air Suspension system effective within a 70% smaller-than-previous enclosure that locks air for a spring-like effect between main and drive cones moving in unison. The result is consistently clear,powerful,wide ranging bass response. The subwoofer's dual cone structure maintains better sound linearity and reliability after hours of hard use than conventional subwoofers with "spider" structures to keep the voice coil aligned. This incredible technology is applied to this new generation of high output, high performance subwoofers.
Double-Stack Magnet with Double-Stack Top Plate
To produce the tremendous magnetic energy we envisioned for this sub, we employed double-stacked magnets, weighing a hefty 110oz, and a double-stacked top plate above them. This design ensures positive, powerful control of the voice coil during those long excursions — and it's one reason you can ring up those high SPL numbers.
Wide-Roll 3-Layer Fiber Radial Surround
A sub's surround plays a key role in a speaker's performance. In order for bass response to be clear and tight, the surround has to respond evenly around its entire circumference without flexing or puckering, even at high volume levels. That's why Pioneer created a surround consisting of two layers of urethane with a layer of interwoven fiber between them. It's strong, stable, and it reduces distortion. In addition, the wider-than-normal design provides a long, linear excursion for excellent control and heavy-duty durability.
To ensure that you get more natural bass, we’ve incorporated out new Basalt fiber technology into our shallow subwoofers. The volcanic-rock fibers create a cone that is lightweight, rigid, well damped, stable in temperature extremes, and more environmentally friendly. In short, this bass really rocks.
Cast Aluminum Basket
Designed from scratch by Pioneer, this one-piece aluminum basket assembly holds the motor assembly, cone, and magnet structure securely in place. The benefits of this design: reduced internal stress, superior damping, and increased magnetic efficiency.
Dual Voice Coil
TS-W3002D2/D4 provides two voice coils, each either at dual 2 or dual 4 ohms. So you can use a low-impedance amp to produce much bigger, much more powerful bass. More options, more power: that's what DVC is all about. The Bridging Adapter is included for an easy Single Voice Coil hookup. It becomes a Single 4 Ohm or Single 8 Ohm with Bridging Adapter for ultimate flexibility for use with modern mono amplifiers
Add Newly Designed Spoke Grilles
We also recommend covering up your subwoofer with the UD-G308 . This stylish spoke grille is a must add-on when building a system and gives the look of pure professionalism.
Features Size 12" Woofer Cone Material Interlaced Basalt/Carbon Fiber Reinforced IMPP Cone Surround Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth Voice Coil Dual 4-Layer, Long Voice Coil Voice Coil Wire Copper Voice Coil Bobbin Phenol Resin Coated Glass Cloth Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (114oz) Basket Design Aluminum Die-Cast Rigid Chassis Gasket 1-Piece ABS Wire Terminals Integrated Single-Sided Silver Compression Terminals Specifications Watts MAX. Music Power 3500 Watts Watts Nominal Power Handling 1000 Watts Frequency Response 20 Hz to 150 Hz Sensitivity 90 dB Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm) Recommended Enclosure 0.50 ~ 1.0 Cubic Feet Dimensions 329 mm x 214.2 mm Mounting Depth 188.8 mm Accessory Grill UD-G308
These are just from Pioneers site, I will get some pics tonight or tomorrow of the boxes. Like I said there brand new. So..
I have 2 12" mass destruction napalm's I think they are D2 if I remember right but don't hold me to that. I have pics of the subs and the box on my phone I will get them uploaded here ASAP..
These are some beast subs, I had a pair in my truck for a bit and they sound good and hit rather hard.. There power ratings seems a little funny though but it can take some power.. I ran a xxx-6500D to 2 of them and they took it like a champ if that tells you anything.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Price $225 each plus shipping..
400 watt min 1000 watts rms-3000 watts peak power 6000 for 5 seconds (BURP)
VIDEOS 1
I remember when they first came out and one of the guys @MD was hyping these up like they were the greatest subs ever made.
I actually heard sum about a year ago and they are better than i expected to be. Thats a good price for these though. Always wanted to build a hybrid w/ these motors.
nice still thread dumping evrey one that is all you do
By no means what i said was a thread dump, if u were around when MD audio first came out you'd know what i was talking about.
I said they were good subs @ a good price lol.
Smoked u truly are a joke.
Retro g/l with the sale, should sell quickly @ ur listed price. They take a good amount of power and can get pretty d*mn loud. I know someone that direct dropped a pair of these 15s and it was louder on meter than a pair of APXs.
People just tend to shy away from MD from all the BS the sent out in the air when they first came around.
RetroAudioinc
RetroAudioinc
Indianapolis, IN
Johnny Drama
