FS: Kicker ZX1500.1
J31Rob
CarTune Netwerk
Kicker ZX1500.1, 2011 model if I recall correctly.
6/10 cosmetic
10/10 functionality
Sat in the back window of a car for about a year and took quite the sun bleaching.. so now it looks copper instead of black. Kinda cool, but also kinda ugly. Missing a mounting foot as well.
Kicker ZX1500.1 (11ZX15001)
Power Output:
750W RMS x 1-Channel @ 4 Ohms
1500W RMS x 1-Channel @ 2 Ohms
General Features
High-Efficiency Class-D Design in most monoblock amps
KickEQ Boost with variable gain up to 18dB centered at 40Hz
Active 50-200Hz variable 12dB/octave XOVER with selectable HiPass, LoPass, or AllPass capability on full-range channels
Active 50-200Hz variable 24dB/octave LoPass XOVER on mono channels
Automatic turn-on options include: 12 volt remote turn-on, DC offset, and audio signal sensing
Differential Hi- and Lo-Level Inputs for integration in any system
Advanced protection circuitry: low/high voltage, over-current, and thermal protection with indication on end panel
All feature FIT Fail-Safe Integration Technology with advanced input design
FIT accepts output from virtually any source unit factory or aftermarket low signal-level to high speaker-level
FIT's isolated inputs reject electrical interference for noise-free operation
FIT's three turn-on modes interface with virtually any vehicle's electrical system
Bass Remote Included
General Specifications:
Frequency Response: 25-200Hz, +0/-1dB
Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V
Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
Active Crossover: 24dB/octave, variable 50Hz-200Hz, low pass only
24dB/octave high-pass subsonic filter fixed @ 25Hz
KICKEQ Boost: Variable to +18dB, centered @ 40Hz
Height: 2-1/8"
Width: 9-5/8"
Depth: 20"
$200 + ship OBO.
UPS or USPS, your call.
Broken mounting foot:
I think the "copper" look is actually pretty sweet looking. Bump for a good amp with a bad *** custom copper finish
hahaha I agree. I had a local guy offer it to me and when I opened it I was like "waaaaaaat is this?" lol. He just had it in direct sunlight so everything bleached out. Does look pretty nice though if you're into that sorta thing. I personally like it too.
Great amp! Does more than rated power.
Yep! I have birth sheet and all that showing over rated.. but I don't put much thought into those.
Bumpity.
J31Rob
CarTune Netwerk
J31Rob
Indiana
J31Rob
