i am selling my kicker kx 1200. i still have bass knob and the birthsheet says 1297 rms... but i do not have the end caps. it has some scrapes on the sides where the end caps cover up and a couple on the front. Everytime i hook the amp up if will switch to protection then switch back to normal mode. but it was working until i blew my sub. i am selling for 150.00 obo plus shipping. this amp i will be selling as is... also i will consider trade for an amp with 800 to 1000 rms at 1 ohm.... i have more pics if needed.... thanks alot...
1200 watts RMS x 1 at 1 ohm
600 watts RMS x 1 at 2 ohms
300 watts RMS x 1 at 4 ohms
1-ohm stable
speaker- and preamp-level inputs
preamp outputs
cooling fan
variable low-pass crossover (50-200 Hz, 12 dB per octave)
variable bass boost (0-18 dB) centered at 40 Hz with wired remote
three-way protection circuitry
Amp Strapping Circuit — allows you to connect a second KX1200.1 amplifier for double the power output
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
Dimensions (with end shrouds): 22-1/2"L x 2-1/2"H x 10"W
1-ohm stable
preamp outputs
cooling fan
