Sold (2) Eclipse 15 inch subs
zlast
For sale. Two Eclipse SW8152DVC. These are the 15 inch, aluminum cone, dual 4 ohm voice coil, 1.3 INCHES of excursion !
Santoprene Surround- Aluminum Cone- Dual Mirror-Image Spiders- Aluminum Voice Coil Former- "Bottomless" Design- Aero-Vented Pole Piece- Cast Aluminum Frame- Double-Stacked Magnet- Small Sealed-Box Enclosure- Continuous Power Handling: 500W- Music Power Handling: 1,000W- New Dual Voice Coil (SW8152DVC)- QCA (Quick Change Assembly)
Perfect operational conditon. COnes have some oxidation, which can probably be buffed out easily. New price is $300-$400 EACH...only $100 EACH plus shipping. I also have the measured T/S parameters if buyer is interested. Contact me via email.
references?? That seems like WAY too cheap.......
I have not conducted any prior transactions via http://www.caraudio.com, are there other references you would find acceptable?
are these the ones with the tc2+ motor?
I must thank you for your inquiry...it made me research the drivers a bit more closely...these are NOT Eclipse SW8152DVC. I purchased these drivers used, and so do not have a manual. Product indentification was soley based on information given to my by the seller. After some inspection BOTH drivers are Eclpise 88150DVC...which retail for $750 each...UPC codes are located under the decorative rubber covers for the magnet structures...
So for clarification these are in fact Eclipse 88150DVC drivers.
no, looks like he's just trying to turn a buck or two. too bad somebody who appreciates those subs didn't buy them to keep.
regardless, these are some bad subs for a nice price. if I had the money I'd consider one myself, I think I actually bid on them but didn't have enough. goodluck to the seller and if you can't move 'em... keep 'em!
edit: might want post your own pics for a little more credibility.
zlast
zlast
none
zlast
michigan born
    May 14, 2026
michigan born
    May 14, 2026
