Sold FS:JL Audio 500\5 Slash Amp
Galante
Quakeman
Minty Condition, no scratches and blemishes with box and manuals. I'm selling because I got new JL amps.
I Accept payments through Paypal.
$350 + shipping
Specifications:
Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Bump For a Awesome amp. I just dont get Why the?
100x2
25x2 //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
250x1
25 to rears //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
Great Amp, Great Price!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
100x2
250x1
rear is less power for rear fill, makes the stereo image 'fuller' not scream as loud as the fronts. sq guys attenuate the rears or, like me, dont use any rear fill at all.
also this is a great amp for an active system, 25 to the tweets 100 to the mids...free bump for a nice amp at a good price...
just a thought a pic with your screen name and a current date would make it much easier selling this amp since you have such a low post count and no refs...
Exactly what I was thinking...hmmm...If I could only get my Audison sold, I would pick this up from you. Trade for my LRx2.4?
Galante
Quakeman
Galante
Nomad
Galante
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
