Sold FS: jl audio 300/4- cheap
snoopysnooper
german engineering= fail
1. Product:
jl 300/4
2. Specs:
Rated Power(stereo): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged): 150 W RMS x 2 @ 3 ohm-8 ohm(11V-14.5V)
THD at Rated Power:
S/N Ratio*: >108.5dB below rated power
Frequency Response: 5 Hz - 30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per. ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (2 pair of inputs)
Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
Speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
3. Description/Condition:
its pretty much mint, it has a chip out of the backside
its not noticable when mounted- pictures make it look alot worse
but sounds freaking amazing
had on d6 6.5s and type s 5.25s and was great
4. Price: :
ASKING 200 shipped
def nego.
snoopysnooper
snoopysnooper
Saratoga Springs, NY
DonRSD
michigan born
    May 14, 2026
michigan born
    May 14, 2026
