FS: Hybrid Audio Technologies Legatia L6SE (Mid-Range, Mid-Bass)
  • 2
Huckleberry Snd
Item(s) for Sale: Hybrid Audio Technologies Legatia L6SE (Mid-Range_Midbass)
Item(s) Description/Condition: Brand New and Un-Used
Price: $565.00 - Firm
Shipping and Miscellaneous Item Information: Free Shipping to the lower 48 states. IF international, contact for shipping info.
Item Pictures: Attached
General Information
These are brand new drivers that have never been used. Please feel free to ask all questions. I have listed all the specifications below. Search the web for reviews and other information. The price is $565.00 and it includes free shipping to the lower 48 states. IF international, please contact prior to purchase. If you are interested in purchasing combined with another listing of mines, please contact for a possible discounted rate. The L3SE are a dream high frequency driver this item.
Brief Description
The Legatia L6SE is a 181mm (7.1-inch) wide-bandwidth midbass/midrange driver to compliment both two-way and three-way system designs, where a point-source midrange and/or dedicated midbass driver is required. The following are the L6SE’s driver specifications.
Driver Specifications
Overall Diameter f181 mm (7.1-inch)
Mounting Depth 78 mm
Bolt Circle Diameter f167.5 mm
Mounting Hole f146.5 mm
Recommended Minimum Crossover Frequency 45 Hz at 24 dB/octave highpass
Pnom Rated power Input (No Crossover) 85 watts (AES Standard)
Pmax Rated power Input (No Crossover) 170 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 225 watts
Frequency Range 50 Hz – 10,000 Hz, +/- 3 dB
Sensitivity 92.5 dB at 2.83V/1meter
Mms 13.466 g
Cms 721 um/N
BL 4.898 T*m
Voice Coil Diameter 35.55 mm (1.4-inch)
Impedance 4
DC Resistance 3.2
Fs 50 Hz (free air)
Qms 1.941
Qes 0.612
Qts 0.466
Xmax 9 mm (one way)
Vas 18.6 L
Sd 13,478 mm2
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
Huckleberry Snd
Huckleberry Snd
Marietta, Ga
Huckleberry Snd
    May 12, 2024
Brendon Jenness
    May 11, 2024
