FS: Hybrid Audio Technologies Legatia L3SE (Mid-Range_Tweeter)
Huckleberry Snd
Item(s) for Sale: Hybrid Audio Technologies - L3SE
Item(s) Description/Condition: Brand New - Un-Used
Price: $380.00 (PM for the quickest response)
Shipping and Miscellaneous Item Information: Free to lower 48 States. Send personal message if international shipping is needed.
Item Pictures: See Attached
Additional info: Online Information
These are brand new drivers that have never been used. Please feel free to ask all questions. I have listed all the specifications below. Search the web for reviews and other information. The price is $380.00 and it includes free shipping to the lower 48 states. IF international, please contact prior to purchase.
The Legatia L3SE is a 93-mm (3.7-inch) “small format” wide-bandwidth midrange/full-range driver to compliment both two-way and three-way system designs, where a point-source midrange and/or full-range driver is required. The Legatia L3SE is the world’s finest multi-purpose super high-end speaker driver. Mechanical and electrical parameters are amenable to a variety of different installations and speaker locations. This driver is intended to be used in an infinite baffle configuration; a simple, solid baffle, solidly attached to the car’s chassis with available airspace at the rear of the baffle is all that is required for optimum operation. The size of the L3SE allows it to be mounted in typical “3-inch” midrange locations within a vehicle, or in custom locations at the discretion of the end-user, as long as there is adequate airspace behind the driver to allow it to maintain proper damping and acoustic suspension.
At home in virtually any arrangement, the L3SE is Hybrid Audio Technologies Legatia SE high-end small-format midrange offering, boasting exceptional performance and a design philosophy that goes hand in hand with true high-fidelity playback.
Thiele/Small Parameters
Overall Diameter 93 mm (3.7-inch)
Mounting Depth 44 mm
Bolt Circle Diameter 84.5 mm
Mounting Hole 74 mm
Recommended Minimum Crossover Frequency 185 Hz at 24 dB/octave highpass
Pnom Rated power Input (No Crossover) 30 watts (AES Standard)
Pmax Rated power Input (No Crossover) 60 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 150 watts
Frequency Range 113 Hz – 18,000 Hz, +/- 3 dB
Sensitivity 89 dB at 2.83V/1meter
Mms 2.46 g
Cms 798 um/N
BL 2.933 T*m
Voice Coil Diameter 25.5 mm (1-inch)
Impedance 4
DC Resistance 3.2
Fs 113 Hz (free air)
Qms 3.602
Qes 0.654
Qts 0.553
Xmax 3 mm (one way)
Vas 1.1 L
Sd 3,117 mm2
For some reason, it does allow me to add pictures! I have contacted those in charge of the form, and awaiting their response. PM me and I can send pics immediately!
Thanks for getting in touch. I am not seeking any trades. IF you desire to make me an offer that is reasonable I may consider it. For that you must send me a personal message.
Thanks
I want to try these so bad...............
The L4's were fantastic sounding.
Any trades?
Thanks
Lol, just sent a message about trades. Your too fast at responding..........
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
4K
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
A Link would be very helpful. Id be interested in taking a look at some gear
193
Huckleberry Snd
Huckleberry Snd
Marietta, Ga
Huckleberry Snd
