FS: Hybrid Audio Technologies - L3v2
  • 1
Huckleberry Snd
Item(s) for Sale: Hybrid Audio Technologies - L3v2
Item(s) Description/Condition: Brand New - Un-Used
Price: $225.00
Shipping and Miscellaneous Item Information: Free to lower 48 States. Send personal message if international shipping is needed.
Item Pictures: See Attached
Online Information
The Legatia L3V2 is a 93mm (3.7-inch) “small format” wide-bandwidth midrange/full-range driver to compliment both two-way and three-way system designs, where a point-source midrange and/or fullrange driver is required. The following are the L3V2’s design attributes:
Thiele/Small Parameters
Overall Diameter f93 mm (3.7-inch)
Mounting Depth 43 mm
Bolt Circle Diameter f84.5 mm
Mounting Hole f74 mm
Recommended Minimum Crossover Frequency 185 Hz at 24 dB/octave highpass
Pnom Rated power Input (No Crossover) 25 watts (AES Standard)
Pmax Rated power Input (No Crossover) 50 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 125 watts
Frequency Range 113 Hz – 18,000 Hz, +/- 3 dB
Sensitivity 88.6 dB at 2.83V/1meter
Mms 2.65 g
Cms 743 um/N
BL 3.277 T*m
Voice Coil Diameter 25.5 mm (1-inch)
Impedance 4
DC Resistance 3.4
Fs 113 Hz (free air)
Qms 2.766
Qes 0.598
Qts 0.492
Xmax 3 mm (one way)
Vas 0.96 L
Sd 3,019 mm2
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
When I first started with upgrades, I purchased a harness that allowed me to add an amplifier by tapping into the factory wiring. It was a PAC...
Huckleberry Snd
Huckleberry Snd
Marietta, Ga
Huckleberry Snd
    May 20, 2024
    May 20, 2024
