2X Shocker Super Extreme 12's
1X Shocker Super Extreme 15
Used motors and baskets on all, OEM dual 2 ohm coils in all. 15 uses OEM coil, cone, spider, tinsels, parts vary on 12's.
12's use same coil, but one has sewn in leads and the other does not (same exact spider, but one has leads attatched). Black basket is Treo, grey basket is RE. Both use direct 8 gauge leads and have carbon fiber/kevlar dustcaps (made by me). Caps aren't super stiff or perfect lay and finish like a show-car bumper, but they are unique, lightweight, and functional.
12's model fair in sealed alignment (2-3 cube) . Ported they should sound good 2-3 cube tuned @ 30hz. They will begin to get a good peak going tuned higher (which would serve well for burps on moderate power).
15 is all OEM shocker parts, but is a train wreck in specs. Vas is @3.5, Fs is @ 32, but Qts is 2.4 which is pretty strange and will likely deliver a monster peak any way you slice it.
Coils are not terribly huge and suspensions are not very stiff. I would say 800-1000W is a good power range for these.
12's 140 ea + shipping
15 100+ shipping
Shipping will be 30-40$ range. Possibly a little more if you're way out of the way.
15 100+ shipping
