Sold FS/FT: DD Z B-2750 Battery
bumpin buick
Science is everything
I have a Digital Designs limited production B-2750 Z battery. The battery works flawless and is in great shape, just needs a new case. I run it without the case though as it provides better cooling to the cells. The battery works great and I have run it daily. It is produced by Batcap and has identical output to their Extreme battery which is equivalent to that of 4 8400s. The extreme retails for about $2000, no idea what retail from DD was but I would like to sell it for either $500 or trade it for a few good 12v batts. This battery held up my z2lv no problems, by itself, which is really impressive. Only reason I am getting rid of it is to go to street classes, where I cant run a multicell up front.
Also with just this battery up front in my chevette I pulled a 158.6 on a single DD z2lv and two 18" Omegas. pretty impressive if you ask me.
Looking for:
HC2400
Powermaster 3100
NSB90
NSB G3100
HC3800
C&D tech batts
Let me know what you got and we will work something out, I will have pics up later tonight.
Specs:
Short Circuit Amps 13,000 +
Length 12 1/8"
Width 8 1/4"
Height 7 7/8"
Overall Height 8 5/8"
8 x 4 gauge in/out .37" / 9.5mm
8 x 0 gauge in/out .514" / 13.1mm
Shipping Weight 75 lbs.
they dont have alot of reserve capacity but they have alot of quick discharge same as a batcap 8400m 8400cca on 16v and 9600amps on 12v first 5sec of a burp.
I was told directly by Batcap that this battery consists of the cells that were used to make the Extreme and specs are identical to the Extreme, which has cells that are 4x as strong as the 8400s, they claim this to have 4 times the power of them... whether that is true or not I do not know but that is what I was told.
im not sure who you taked to but thats not what ray has told people in the past team neo vern as the same battery its a bada$$ little battery but it was the same as a 8400m dd will tell you the same thing i been running batcaps for along time know still a great battery but not great on the reserve for daliy when dd sold these the were $1500 each plus shipping glws.
bumpin buick
bumpin buick
Appleton, Wisconsin
bumpin buick
