Sold fs/ft american bass xd300d $375 shipped
mjf
For sale is an American Bass XD3000d, bought this from breakjunki a few months ago, been running two RD audio alpha d4s @1 ohm, never broke a sweat.
This was repaired from Chris @ DB-r, and I've never had a single issue with it, just looking for something new, maybe alittle more power.
XD-3000 Amplifier Specifications:
Power Output @ DC 14.4V:
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch. @18V
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
Pictures
it does have it's shares of scratches and otherwise, as would be expected for a used amp.
any questions are welcomed
If there were another one around I'd snatch yours and another one up
Too bad for only one though man //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
theres two others for sale on usaci, same price roughly
I have a 15" xxx and two 10" type r's
ill pass, thanks though.
what do you have?
Do you know if this amp is the same thing as the Solid Audio F2500D? I've got one already, and would love another to strap with it. From Ampguts they look identical, but they could use different components.
Killer amp either way, its never let me down.
well aware of that one, its the same board, but there could be slightly different components, so im not 100% on whether it would strap.
mjf
mjf
asdf
mjf
