fs/ft Alpine MRV 1005
zwhore
Alpine MRV 1005
RMS Power (at 12V, 20Hz—20kHz)
Per channel into 4 ohms ........................................................... 100W x 2 (0.08% THD)
Per channel into 2 ohms ............................................................. 200W x 2 (0.3% THD)
Bridged 4 ohms ....................................................................... 400W x 1 (0.3% THD)
RMS power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms ........................................................... 150W x 2 (0.08% THD)
Per channel into 2 ohms ............................................................. 300W x 2 (0.3% THD)
Bridged 4 ohms ....................................................................... 600W x 1 (0.3% THD)
General
Frequency Response ................................................................ 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............................................ 110 dBA (referenced to rated power)
Input Sensitivity (for rated power) ............................................................... 200mV to 4V
Slew Factor ......................................................................................... greater than 5
Input Impedance ......................................................................................... 10k ohms
Speaker Impedance ............................................. 4 or 2 ohms (stereo), 4 ohms (bridged)
Dividing Network .................................................. 50Hz—200Hz HP/LP(12dB/octave)
Equalizer Center Frequencies ................................................................ 50Hz—200Hz
Q Factor (bandwidth) .................................................................................... 10 — 1
Boost and Cut range .......................................................................................±12dB
Power Requirements ...................................................... 11—16V DC (negative ground)
Heat Sink (WxHxD) ............................ 240mm x 53mm x 330mm (9-7/16"x2-1/16"x13")
Foot Print (WxHxD) ............................ 260mm x 53mm x 330mm (10-1/4"x2-1/16"x13")
Weight .......................................................................................... 4.4kg(9lb. 11oz.)
200.00 plus shipping or trade for Audio Art amps or a Memphis belle
Shipped via ups ground
zwhore
zwhore
Murrieta Ca
zwhore
