FS/FTAlpine MRV-F505
zwhore
Alpine MRV-F505
RMS Power (at 12V, 20Hz—20kHz)
Per channel into 4 ohms .................................................. ........... 50W x 4 (0.08% THD)
Per channel into 2 ohms .................................................. ............. 65W x 4 (0.3% THD)
Bridged 4 ohms .................................................. ..................... 130W x 2 (0.3% THD)
RMS Power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms .................................................. ........... 75W x 4 (0.08% THD)
Per channel into 2 ohms .................................................. ........... 100W x 4 (0.3% THD)
Bridged 4 ohms .................................................. ..................... 200W x 2 (0.3% THD)
General
Frequency Response .................................................. .............. 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............................................ 105 dBA (referenced to rated power)
Input Sensitivity (for rated power) .................................................. ............. 200mV to 4V
Slew Factor .................................................. ....................................... greater than 5
Input Impedance .................................................. ....................................... 10k ohms
Speaker Impedance .............................................. 4 or 2 ohms(stereo), 4 ohms (bridged)
Dividing Network ................................. 50Hz—8000Hz HP/LP/Bandpass(12dB/octave)
Power Requirements .................................................. .... 11—16V DC (negative ground)
Heat Sink (WxHxD) ..................... 240mm x 53mm x 400mm (9-7/16"x2-1/16"x15-3/4")
Foot Print (WxHxD) ..................... 260mm x 53mm x 400mm (10-1/4"x2-1/16"x15-3/4")
Weight .................................................. ........................................ 4.5kg(9lb. 14oz.)
Works perfectly. Crisp clear sound. Very underrated. I do have the cover for the x-over.
250.00 plus shipping or trade for Audio Art amps or Memphis Belle
Shipping via ups ground.
zwhore
zwhore
Murrieta Ca
zwhore
