FS Focus HO Alt
12voltz+-
1. Product:
DB electrical high output alternator
2. Specs:
220amp fits 2000-2004 ford focus
Voltage Set Point – 14.5 Volts
Internal Voltage Regulator
Under Full Load Conditions, amperage output at 600engine rpm (idle) will peak at 110 Amps.
Under Full Load Conditions, amperage output at 1200engine rpm will peak at 220 Amps.
NEW ALTERNATOR HIGH OUTPUT 220 Amp 2.0L FORD FOCUS 2000 01 02 03 04 ZETEC | eBay
3. Description/Condition:
BNIB never used bought this a few weeks later sold the car
4. Price: :
185shipped !
5. Pictures:
no no, the voltage when the car is running is 13.8-14.5 roughly this is a health charging state for a 12 volt battery when the car if off the battery should sit around 12.6v...... this will not increase voltage so to speak..... but the current or amps need to supply all of your power sources and with having that it will stabilize the voltage... that answer it?
12voltz+-
12voltz+-
lorain OH
PuMpDatBaSs420
