up forsale is my z1a. amp is in great condition. few minor blemishes on the casing nothing major. cosmetic wise 8/10. performance wise 10/10/. never seen below 13v as far as i know from me and the previous owner. was just at carlisle with it so people have seen it perform. i am lookin for $770 shipped. do not try and low ball as i will just ignore it. i dont have any pics with user name as of now but heres a couple of it in the car. i have a bunch of refs. thanks
rich
http://www.caraudio.com/forum/showthread.php?t=395577
SPECIFICATIONS
Series
Z
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
35 Hz - 250 Hz at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
Z1a
Cont Power at 4 ohm
1250W-1750W x 1ch 12v - 14v
Cont Power at 2 ohm
3500-4000W x 1ch 12v - 14.4v
Damping Factor
>450 @ 1 ohm
Cont Power at 1 ohm
5000W-5500W x 1ch 12v - 14.4v
Dynamic Power
7072W x 1ch
Efficiency thru Output
>86% 14.4v
Dimensions - mm
685.8 L x 304 W x 70 H
Dimensions - inches
27 L x 12 W x 2.76 H
Signal to Noise
85 dB
Shipping Weight
43 lbs
rich
SPECIFICATIONS
Series
Z
Input Sensitivity
0.2V - 8V
Subsonic Filter
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
Z1a
Cont Power at 4 ohm
Cont Power at 2 ohm
Damping Factor
>450 @ 1 ohm
Cont Power at 1 ohm
Dynamic Power
7072W x 1ch
>86% 14.4v
Dimensions - mm
Dimensions - inches
Signal to Noise
85 dB
Shipping Weight
43 lbs
