Sold FS: Digital Designs m1a
Series
M
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
20 Hz - 200 Hz at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
M1a
Damping Factor
>250 @ 1 ohm
Power at 1 ohm
1200W x 1ch
Power at 4 ohm Mono
300W x 1ch
Max Dynamic Power
2000W x 1ch
Efficiency thru Output
>75%
Dimensions - mm
300 L x 235 W x 53.4 H
Dimensions - inches
11.81 L x 9.25 W x 2.1 H
Signal to Noise
85 dB
Shipping Weight
12 lbs
Here are some pics:
They are too dark I think. The display on my camera is all white, so I cannot see to change the settings I will take some better ones in the sun on Saturday
Flipx99
Violator of Terms
Flipx99
Building 100
Flipx99
