Digital Designs C4a 4 channel amplifier
Series: C
Input Sensitivity: .2V-8V
Variable High Pass Filter2: 20 Hz - 5kHz at 18dB/Oct Izuka
Subsonic Filter: ---
Variable Low Pass Filter: 50 Hz - 5 kHz at 18 dB/Oct Izuka
Clipping Display: LED
Tested Voltage: 14.4V
Tested THD: 1%
Model: C4a
Cont power at 4 ohm: 100W x 4ch
Cont power at 2 ohm: 150W x 4ch
Damping Factor: >250 @ 2 ohm
Cont power at 1 ohm: 175W x 4ch
Cont power at 4 ohm Mono: 300W x 2ch
Cont power at 3 ohm Mono: 350w x 2ch
Dynamic Power: 400W x 2ch
Efficiency thru Output: >65%
Dimensions - mm: 380 L x 235 W x 53.4 H
Dimensions - inches: 14.96 L x 9.25 W x 2.1 H
Signal to Noise: 92 dB
Shipping Weight: 14 lb
Used, good cosmetic condition. Will get more pics per request.
$235 shipped in the lower 48
Fedex
Series: C
Tested THD: 1%
Model: C4a
Fedex
