FS: Digital Designs C4a 100x4 1 ohm stable
  • 4
groundpound4200
Da fuq did I just read?
5,417
Mankato, MN
Digital Designs C4a 4 channel amplifier
Series: C
Input Sensitivity: .2V-8V
Variable High Pass Filter2: 20 Hz - 5kHz at 18dB/Oct Izuka
Subsonic Filter: ---
Variable Low Pass Filter: 50 Hz - 5 kHz at 18 dB/Oct Izuka
Clipping Display: LED
Tested Voltage: 14.4V
Tested THD: 1%
Model: C4a
Cont power at 4 ohm: 100W x 4ch
Cont power at 2 ohm: 150W x 4ch
Damping Factor: >250 @ 2 ohm
Cont power at 1 ohm: 175W x 4ch
Cont power at 4 ohm Mono: 300W x 2ch
Cont power at 3 ohm Mono: 350w x 2ch
Dynamic Power: 400W x 2ch
Efficiency thru Output: >65%
Dimensions - mm: 380 L x 235 W x 53.4 H
Dimensions - inches: 14.96 L x 9.25 W x 2.1 H
Signal to Noise: 92 dB
Shipping Weight: 14 lb
Used, good cosmetic condition. Will get more pics per request.
$235 shipped in the lower 48
Fedex
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
groundpound4200
groundpound4200
Mankato, MN
groundpound4200
