Sold FS : Car audio and Home Audio - closet clearing
tyroneshoes
886
NJ
Hey. I have a bunch of stuff I'm trying to get rid of. Ill start with the car audio. All prices dont include shipping from 08872.
ry%3D320
Sony mobile ES xm-4026 - 50x2 rms at 14v. 1 ohm stable but used as a wonderful tweeter amp. Good Sony Japanese quality. $50 + shipping
Audiocontrol 3xs. I believe all the modules are 90 hz but not sure. $60 + shipping
ry%3D320
Then I have a great old school SS exact 12 svc4 ohm. The cork was damaged and I removed it and replaced it with a rubber gasket from robotunderground. You WILL need to glue the surround to the basket as in some areas it became detached. An easy job to do and in great condition otherwise. I used it as it is and it sounded great so the leaks are really not that bad but it is a fixer. $ 90 + shipping
ry%3D320
Then I have an old xtant A 10" svc 2 ogm sub. Not bad. Good for a GF or friend. Basically this is an MTX Blue Thunder and not a bad sub at all. $40 + shipping.
HOME AUDIO
ry%3D320
ry%3D320
I Have a Mitsubishi 2 channel amplifier. It produces a minimum of 100 watts a channel @ .05 thd at 8 ohms and states to be 4 ohm stable though I had them running my 6 ohm bookshelves wonderfully. Not bridgable. These are very solid units and high end at the time. I have the entire rack system (preamp, cd changer, tape and same amp) Id sell as well. Amp is heavy, about 20 pounds. I have two of these. Great amps. $100 + shipping
ry%3D320
ry%3D320
Then I have the AARPA 6 channel amp that were hot a while back. Mine is set up as 3 bridged channels and I used it to run two small bookshelves and a 6.5 TB sub. Great amp. Just dont need it. All the channels are bridged and its about 60x60x75 at with an 8 ohm load. Perfect for a bedroom and all set up for you. $80 plus shipping.
Feel free to ask anything you want. If youd like the Mitsubshi rack, check out this older post.
http://www.diymobileaudio.com/forum/showthread.php?t=8120
and a pic. Comes with a learning remote with a graphic EQ on the actual remote.
ry%3D320
tyroneshoes
tyroneshoes
NJ
tyroneshoes
