Sold FS: Budget Headunits and Amps w/ specs
2002XLT
Thats right bishes...
Going to update this thread with all the specs. All items are in used condition and show signs of use. Nothing will be included except what is in the pic. Ill try and answer all questions to the best of my abilities on specific items.
ALL PRICES ARE OBO, so send me pms with your offers.
Pioneer CD Player Model# DEH-245 - Works 100% $40 shipped
FEATURES:Supertuner III;24-station/6-button (18FM/6AM) presets;BSM (Best Stations Memory);AGC (Automatic Gain Control) for optimum CD tracking performance;35Wx4 - 4-channel high power;RCA Preouts (x1 pair) (Front);Electronic Bass, Treble and Loudness;Liquid Crystal Display
Pioneer CD Player Model# DEH-1900MP - works 100% $55 Shipped
http://reviews.cnet.com/satellite-radio-tuners/pioneer-deh-1900mp-radio/4507-7873_7-32400006.html?tag=mncol;rnav
Xtreme Sound CD Player Model# WMS336RW - works but one of the knobs is broken, im not sure what function this knob is used for but you can see it in the pic. its not any of the basic functions - $25 shipped
Clarion CD Player Model# DRX7475 - works perfectly $75 shipped
Cant seem to find any specs on this one, but it has 3 4 volt preouts
- Kenwood CD Player Model# KDC-319 - works perfectly - $55 shipped
KEY FEATURES
Flip-Down Removable Faceplate with Carrying Case
Full Bandwidth Power (less than 1%% THD): 22 Watts x 4
Maximum Output Power: 50 Watts x 4
Preouts: Front, Rear
Remote Control: 10-Key
Sirius Satellite Radio Ready
System Q Sound Control
LCD Display: High-Resolution Color with White LED Bac
GENERAL FEATURES
Clock
Display Readout: 14-Segment
Finish: Silver/Gray
Iso-Mount Capability for Japanese Vehicles
Sub Illumination: Blue
Illuminated Function Buttons: Green
LCD Display: High-Resolution Color, with White LED Ba Touch-Tone Buttons: Defeatable
POWER RATINGS
AUDIO FEATURES
Attenuator with Smooth Volume Return
Electronic Audio Control (Volume, Balance, Fader)
Front/Rear Fader
Loudness Control
Source Tone Memory
Tone Controls: Bass, Midrange, Treble
COMPACT DISC FEATURES
Digital Filter: 8-Times Oversampling
Digital Optimum Servo Control
Digital to Analog Converter: Integrated Quad 1-Bit
Intro Scan
Play/Pause
Plays CDs, CD-Rs and CD-RWs
Precision Digital Timing (DPAC)
Random Play
Repeat Play
CHANGER CONTROL FEATURES
CD Text Display
Changer Control: 2, 1+ Aux (w/KCA-S210 or Compatible Chan
Disc Name Preset Play
Disc Naming
Play Time Display
Random Play: Disc, Magazine
Repeat Play: Track, Disc
Scan: Track, Disc
TUNER FEATURES
Automatic Memory Entry
DAB Tuner Control
High-Speed Multipath Control (CRSC) with ANRC
Kenwood CR-2 Advanced Tuner
Seek Tuning
Station Presets: 24 (18FM, 6 AM)
Clarion CD Player Model# Db336MP - works 100% $45 shipped
http://www.sonicelectronix.com/item_319_Clarion+DB336MP.html
amps
Kenwood Model# KAC-7201 works 100%
$100 Shipped
150 watts RMS x 2 at 4 ohms
230 watts x 2 at 2 ohms
460 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
MOSFET power supply
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
variable low-pass crossover (50-200 Hz at 18 dB per octave)
selectable high-pass crossover (150 Hz at 12 dB per octave)
selectable bass boost (12 dB at 90 Hz)
preamp- and speaker-level inputs
preamp outputs
cooling fan
13-5/8"W x 2-5/16"H x 11-1/4"D
Proacoustic Model# PRAM 240 works perfectly,
$75 shipped, says 2 channel 2400 watts, but it has 2 25 amp fuses so do the math, also someone decided to use regular screws for the terminals.
Pioneer Model# GM-X262 works 100% and is in good cosmetic condition
$40 shipped
http://www.shopping.com/xPF-Pioneer-GM-X262
seems like those specs are extremely low, but its all i can find. Says its a 200 watt amp.
Jensen XA-1120 works perfectly, has regular screws for termianls.
$25 shipped
3 CH: 2 x 75 Watts RMS (4 ohms) [2 x 150 Watts peak] + 1 x 150 Watts RMS Bridged (8 ohms) [1 x 300 Watts peak]
2 CH: 2 x 55 Watts RMS (4ohms) [2 x 110 Watts peak]
2 CH: 2 x 83 Watts RMS (2ohms) [2 x 166 Watts peak]
1 CH: Bridged 166 Watts RMS (4 ohms) [332 Watts peak]
Power Rating@
4-channel design bridgeble to 6-channel
Switchable low pass crossovers for driving subwoofers @ 100Hz reduce distortion and extend speaker life
MOSFET power supply for cooler, more stable operation
2 ohm stable operation for maximum efficiency
Bass Boost +6db @ 45Hz; Circuit and thermal overload protection prevents amp failure
Variable input sensitivity for perfect match with car stereo
Floating ground inputs
Gold-plated low level inputs and screw terminal connections for: power, ground, sensing and speaker outputs
Discrete bi-polar output transistors for maximum efficiency
Remote on/off sensor turns amp on and off with car stereo
Power LED indicator
State-of-the-art heat sink for efficient power dissipation
Soft turn-on circuit
Cool Diamond-Plate finish
2002XLT
2002XLT
H-Town, TX
BeAlLsTaR13
