FS: Blown RD Audio 3250
NoPh33rRaCiNg
1. Product:
Blown Rd Audio 3250V2 amp
2. Specs:
* Digital class-D linkable mono block amplifier
* MOSFET PWM power supply
* Daisy-chain through output RCA
* Double sided through hole epoxy PCB
* Stable into 1 ohm and 2 ohm parallel amplifier connection availability
* 24dB/oct variable crossover
* Variable subsonic filter
* Variable bass boost
* Variable low pass filter
* Variable phase shift
* Efficiency : 86% @ 4 ohm, at 100Hz
* Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
* RCA line input
* Tested voltage & THD : 14.4V & less than 1% THD
* Operating voltage : DC 10V~18V power input- 2008 models
RMS power, 2 ohm linkable/dual mono 5600w x 1ch RMS power, 0.875 ohm mono 3750w x1ch RMS power, 1 ohm mono 3000w x1ch RMS power, 2 ohm mono 1500w x1ch RMS power, 4 ohm mono 750w x1ch Signal to Noise Ratio >100dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
3. Description/Condition:
Blown. Turns on for few seconds, then turns off. Protect light flashes when it turns off but doesn't stay on. Could get it fixed, I do not have any quotes from anyone. I do have the bass knob, not sure if it works I never used it, you will need to get the 5-pin phone cord for it. I cannot see any visible burn marks on the board.
4. Price:
100 + shipping
5. Pictures:
hey dylan , if you get it , i'd be interested in going thru it and giving a go at a repair. Worst case scenario is you are out shipping moneys if i can't get it fixed. Or i can drive it to ampmedics. LOL. It's not too far from where i live. I would only charge cost of parts for you. I just want something to tinker with at night. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sweet! If I can't manage to fix it, I'll definitely do that!
NoPh33rRaCiNg
NoPh33rRaCiNg
Kent, WA
Bassin Buick
michigan born
    May 14, 2026
michigan born
    May 14, 2026
