FS Batteries CHEAP!!!!!
michaellane
Don't pay $60-100 for a used HC600 or Batcap 800, or even more for a XS D680...get more power reserve, and for less $$!
26ah rating
7" long x 6.5" wide x 5.2" to top of tabs (rounded up a tiny bit)
Totally sealed and non-spillable AGM technology
40% more weight and higher ah rating than a Kinetik HC600
All load test just like they're supposed to.
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep up
Never used batteries only opened the box to test them
$45.00 shipped trades need to be sent via PM
are you running the system in your sig? but at the moment yes. I don't want to ship the bigger ones honestly
Building a new 6cu box tuesday and picking up another hds312 and will be running at 1-ohm so I am looking for a larger under the hood battery. The BK1800 will do 1.9-2k without clipping on clean power. Which is why I am looking for a replacement to my standard red top
I didn't think they were putting out that much power. well this is all im selling and shipping right now. if you have the big 3 done and a decent alt you could do a couple of these but either way good luck with your build
Just wait and have the subs in first and monitor your voltages then do upgrades as needed depending on the full blast voltages.
Great seller and a stout little product. I have not had the opportunity to use this as a car audio reserve battery, but we ended up using it on our test bench for misc mechanical and electrical parts and it does great. Enough juice to turn over small lawn equipment (mowers).
michaellane
michaellane
tx
michaellane
