FS: Banda 7k High input version
Boomsday
My House
Banda 7k High input version 6v
Used, has had the 6v input mod done. I have had this one for a few years still works great. Only selling because its an extra and I saw something I wanted.
$600shipped
FFFFFFFFFF WHY YOU DO THIS TOO ME chauncey!! I was gonna get a brand new SQ oriented 4 channel amp. Whats the 6 volt input mod do?
Pretty much allows you to run a more up to date hu and adjust the gain as such. anybody that has used the stock ones know that you can not turn the gain barely at all if you have higher then 2v pre outs
I think i have some dual inputs i could throw in as well they are like 30bux but i will throw them in for free. One of them has some arc damage but i can sand it back smooth if needed
what would you say would be elctrical to push this? how big of a bat bank with a 320A alt
I think this may be the one I had.
I ran it on a 320 amp Singer hairpin and one XS D3100. Voltage was great, but also consider that I have a high idle speed (1,500 rpm+) and very short lengths of wire. I'd say at least one solid group 31 in the back would be fine
Nah I have 5 of them this is my og one. Im selling this one because the factory low sub mod is different then the one i did and I just want them all to match
Oh, didn't know that.
What exactly is your system right now?
currently
2 team fi 15s
2 banda 7ks
3 xs power 3ks
6 banks of supercaps
300amp alt
Gonna see how the subs hold up on 1 amp per sub may add 1 amp per coil soon tho just for comps tho
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
306
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
912
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
763
Boomsday
Boomsday
My House
Boominburban
Decebal
    Jun 10, 2024
