Sold Fs: Amps, In Dash Eq, Midrange Speakers
ENDER_XVICM
I have some amps and such left over from a previous install.
Everything is in great condition, but one amp has a nick on a fin.
Not real noticeable though and it can be hidden.
I have the following amps:
Cadence ZRS 5004( I have two available): ($100 shipped)
4 Ohm RMS Power: 4 x 50 Watts @ 13.8 Volts
2 Ohm RMS Power: 4 x 100 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 2 x 200 Watts @ 13.8 Volts
Frequency Response: 10Hz - 40KHz
Channel Seperation: >65 dB
S/N Ratio: >100 db
Damping Factor: >200 @ 100Hz
Minimum THD:
Input Voltage: 200 mV - 8 Volts
Dimensions: 11.5" x 9.4" x 2.4"
Cadence ZRS 1502 (I have one available): ($135 shipped)
4 Ohm RMS Power: 2 x 150 Watts @ 13.8 Volts
2 Ohm RMS Power: 2 x 300 Watts @ 13.8 Volts
4 Ohm Mono RMS Power: 1 x 600 Watts @ 13.8 Volts
S/N Ratio: >100 db
Minimum THD:
Dimensions: 15" x 9.4" x 2.4"
I have the following in Dash EQ:
Cadence CEQ-810 ($60 shipped)
One Set of Low Level RCA Inputs with Level Adjustment
One Set of High Level Inputs
3-Way Output: Front, Rear and Subwoofer
Sub Out Low Pass Control :
Frequency Control: 40-150Hz
Output Level Control
7 Band EQ Adjustablity
Band 1: 60Hz
Band 2: 150Hz
Band 3: 300Hz
Band 4: 1,000Hz
Band 5: 3,000Hz
Band 6: 6,000Hz
Band 7: 15,000Hz
Frequency Boost and Cut: 12dB
Frequency Response: 10-35,000Hz
THD:
S/N Ratio: 105dB
Maximum Output: 7 Volts
Demensions: 7" x 1" x 4.5"
4 Preset DSP Equalizations
Rock, Pop, Classical, and Flat
7 Band Manual Control
Front and Rear Separate Equalization Adjustments
Full Screen Cacum Florescent Display with 6 Display Modes
4 Channel Digital Sound Position Adjustment
Digital Gain Adjustment
Input Level Adjustment
Flip Down Front Panel
Front Panel Auxiliary Input
Dimensions: 7" x 2" x 7"
I also have a pair of midrange drivers
CDT ES-5 ($115 shipped)
For specs on this dirver PM me
it is 50W RMS @4 ohm
ENDER_XVICM
ENDER_XVICM
Reading, PA
ENDER_XVICM
