SOLD FS: Amps & Speakers - ARC, Hertz, MTX, Clarion
undeadxsunshine
what it is
1,297
York, PA
As some of you guys know I recently totaled my car. So I decided to sell off most of my system seeing as I have no car to use it in right now and could really use the money. I'm also gonna go a slightly different route with my new system when I get a new car. Prices are fairly firm considering I'm not in great need to get rid of this stuff but make an offer if you want. No trades. But the extra money would def help going towards my new car and the ticket I got because of the crash. Anyways here's what I got, I have plenty of refs too. All prices are shipped.
ARC Audio KS 300.4
Amazing amp, ARC is top quality stuff. This was used for around 6 months. It gets 10/10 mechanical and 9.5/10 cosmetic. Some very tiny scratches on the one side, you can't even see them from a couple feet away. Picture makes the scratches look worse then they are, but i got a close up of them.
Specs from arc (quite underrated though):
Power output RMS @ 4 ohms 4 x 90 watts
Power output RMS @ 2 ohms 4 x 175 watts
Power output RMS @ 4 ohms bridged 2 x 350 watts
Transient Distortion (100 watts) Frequency Response 20Hz - 20 KHz
Signal to Noise Ratio >95dB
Bass Boost +18db@45Hz
Crossover (Butterworth) 55Hz - 5.5 KHz variable 12dB
Fuse 30A x 3
Size 13.0"(L) x 8.0"(W) x 2 3/8"(H)
$350
MTX Thunder 500D
Nice little old school made in america amp here, pushed my Hertz HX300D very well. It gets 10/10 mechanical and 7.5/10 cosmetic.
Specs from ampguts:
RMS Power at 12.5V:
1 x 250W @ 4 ohms (
1 x 500W @ 2 ohms (
Dynamic Power at 14.4V (IHF-202):
1 x 450W @ 4 ohms
1 x 775W @ 2 ohms
S/N Ratio: 100dBA
Damping Factor: >200
Freq. Response: 20Hz ∼ 200Hz
Fuse: 3 x 25A
Dimensions: 9" x 9" x 2" (22.8cm x 22.8cm x 5cm)
$100
Clarion APA250
Nice little 2 ch amp, works well. 8.5/10 cosmetic, 10/10 mechanical.
Rated at 50x2 w RMS @ 4 ohms, 100x2 w RMS @ 2 ohms.
$40
I'm listening to my ARC coaxial speakers on my arc amp right now, have them cranked pretty loud and they still sound great. Not sure what that noise was that I heard before. $40 is a great deal.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
what if I wan this AMP with a P2 Rockford sub https://rockfordfosgate.com/products/details/p1000x5/ Had one shop quote me at 1100 for everything...
15
4K
447
571
undeadxsunshine
what it is
undeadxsunshine
York, PA
evo286
