Sold FS: American Bass XD3000D $375 shipped
mjf
For sale is an American Bass XD3000d, bought this from breakjunki a few months ago, been running two RD audio alpha d4s @1 ohm, never broke a sweat.
This was repaired from Chris @ DB-r, and I've never had a single issue with it, just looking for something new, maybe alittle more power.
XD-3000 Amplifier Specifications:
Power Output @ DC 14.4V:
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch. @18V
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
Pictures
Factory ratings: XD20001 x 500 Watts @ 4 ohms
1 x 1700 Watts @ 2 ohms
1 x 2200 Watts @ 1 ohm
sure seems like it to me, the XD2000 ratings are a bit all over the place. according to ampguts, it puts out more power @ 2 ohms than the 3k, which doesnt make any sense whatsoever.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
the 3000 makes sense, close to double ratings from 4, 2 ,1.
however the 2000 is 500, 1700, 2200.
so it more than triples in power when wired at 2 from 4, then less than a 30% when wired @1ohm, bullllshhiittttt.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
The XD2000 is a bit over rated, drop it by about 500watts. Still good amps. Good luck with the 3000 sell. Wish I had the $ for it
mjf
mjf
asdf
mjf
