FS: 55ah DEKA batts
michaellane
55ah batts
In the box
$90 shipped each
im pretty sure those are just add ons and you can take them off. Its weird that i cant seem to find any pictures of that battery with a sealed top terminal and only side ones.
You should definitely check and see if they come off.
According to deka,(east penn) if it ends in a dt, as in 9A78DT, it is dual terminal. Since this does not, I would assume that it is a side terminal only battery.
which then makes it group 78 as was said earlier ... And these bad boys are $175 PLUS SHIPPING elsewhere on the net... Killer deal right here guys ....
Deka 9A78 AGM
Intimidator Battery
Group size: 78
Cold Cranking Amps (CCA): 775
Black cover with a gray case
Includes a handle
Features:
Enhanced electrolyte suspension system
Special glass mats absorb more electrolyte
Premium maintenance-free
starting and cycle service power
Vibration protection safeguards
battery performance over time
Fast recharging powers more
electronics longer
Spillproof design
Designed to hand factory installed
electronics to anything that plugs in
or turns on, and still deliver
2x the endurance in severe service,
as well as 2x the cycle life
Equipped for the toughest conditions
and the most intense electrical power demands
Ideal for tuner cars or off-road vehicles,
offering superior power for high-performance
equipment and a high-impact design
for rugged, back road adventures
Benefits:
Advanced durability design
Fortified posts, straps,
and welds
Resists vibration damage
Maximizes current transfer
over life of battery
Power-Perform® full-frame positive
and negative plates
Withstands severe service demands
Prevents life-robbing electrical shorts
from exposed wire
Absorbs more electrolyte
Protects internal components
Micro-porous glass separators prevents
acid spills and terminal corrosion
Not the best picture but a better one. Is it ok to solder in two 4 awg wires(going to seperate amps) onto one 1/0 ring terminal? i assume two 4awgs would fit into a 1/0 ring terminal. If not step up to a 2/0 ring terminal.
michaellane
michaellane
tx
big scott
BP1Fanatic
BP1Fanatic
