FS: 55ah DEKA batts
michaellane
tx
55ah batts
In the box
$90 shipped each
im pretty sure those are just add ons and you can take them off. Its weird that i cant seem to find any pictures of that battery with a sealed top terminal and only side ones.
You should definitely check and see if they come off.
They are group 78 and are 10 3/4" x 6 7/8" x 8" tall. and 42.5 lbs each
thats what another member posted. The box says 46lbs. Ill meassure them tomorrow for you
Fixed. Group 34/78 has both top and side terminals.
Im looking for a good hood agm under 11" in length, I need the biggest for that size, but I dont want to spend $270+ on a XS D3400R, yet
Give me your exact dims that you need to stay under
Thats what i thought too but the pic says otherwise. I just want picture verification that there is a top terminal.
Ill look after work and ill see. Im pretty sure there isnt a top post spot but m8ght be wrong
According to deka,(east penn) if it ends in a dt, as in 9A78DT, it is dual terminal. Since this does not, I would assume that it is a side terminal only battery.
which then makes it group 78 as was said earlier ... And these bad boys are $175 PLUS SHIPPING elsewhere on the net... Killer deal right here guys ....
Deka 9A78 AGM
Intimidator Battery
Group size: 78
Cold Cranking Amps (CCA): 775
Black cover with a gray case
Includes a handle
Features:
Enhanced electrolyte suspension system
Special glass mats absorb more electrolyte
Premium maintenance-free
starting and cycle service power
Vibration protection safeguards
battery performance over time
Fast recharging powers more
electronics longer
Spillproof design
Designed to hand factory installed
electronics to anything that plugs in
or turns on, and still deliver
2x the endurance in severe service,
as well as 2x the cycle life
Equipped for the toughest conditions
and the most intense electrical power demands
Ideal for tuner cars or off-road vehicles,
offering superior power for high-performance
equipment and a high-impact design
for rugged, back road adventures
Benefits:
Advanced durability design
Fortified posts, straps,
and welds
Resists vibration damage
Maximizes current transfer
over life of battery
Power-Perform® full-frame positive
and negative plates
Withstands severe service demands
Prevents life-robbing electrical shorts
from exposed wire
Absorbs more electrolyte
Protects internal components
Micro-porous glass separators prevents
acid spills and terminal corrosion
A piece of cable is cheaper than a diff batt ....
Well im a lil lost on how to do it. I have two 4 awg ring terminals+ 1 awg ring terminal(from alt)+ stock wire. All on one post
Kinda just a mess and not sure how to do it right.
What adapters do you mean?
Not the best picture but a better one. Is it ok to solder in two 4 awg wires(going to seperate amps) onto one 1/0 ring terminal? i assume two 4awgs would fit into a 1/0 ring terminal. If not step up to a 2/0 ring terminal.
michaellane
michaellane
tx
big scott
    May 12, 2024
Brendon Jenness
    May 11, 2024
