Sold FS 4 Channel JL, Zapco, Kenwood
JayRich
First up is the Zapco i-Force i-450 4 Channel Amp here are the specs listed on woofersetc.com
4-Channel with Crossover and Remote Bass
-Balanced line input for OEM integration
-Unbalanced RCA input
-RCA output
-Bridgeable 4-channel amp
-MOSFET power supply
-Bass equalization
-Variable electronic crossover
-Remote bass gain
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. :
Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=594
This is an Excellent SQ amp and since i've upgraded power to the 300/4. It is listed on the site for $229.99, I'm looking for $150 Shipped OBO Cosmetic 9/10 function 10/10
Next up is the JL Audio 300/4
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 75 W x 4
RMS Power at 2 Ohms: 75 W x 4
Performance
Frequency Response: 5 Hz - 30000 Hz
Signal to Noise Ratio: 108.5 dB
THD at Rated RMS Power: 0.03 %
Crossover / Equalizer
Low - Pass Frequency: 50 Hz - 5000 Hz
High - Pass Frequency: 50 Hz - 5000 Hz
Other Features
Input Voltage: 11 volt
MOSFET Circuitry: Yes
Dimensions
Width: 9.25 in.
Depth: 13.4 in.
Height: 2.36 in.
Got this on a local trade but just purchased one 2 weeks ago, so I have no need for it I'm looking for SOLD Cosmetic 8.5/10 function 10/10
Last up is a Kenwood KAC-7495 4 Channel amp. This has been in a closet for a few years now, and I've taken it out and tested it to make sure that it works. I'm not sure of the specs but I know it puts out 45X4 at 4Ohms. Looking for $50+Shipped OBO Cosmetic 6/10 Function 10/10
What's the bottom line shipped on that zapco?
You still owe me a good deal for the hole in that Q! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Did you mean the Q that I bought off you?? ok well I can do $150 shipped
JayRich
JayRich
Richmond, VA
JayRich
