Sold Fs-2 Re *** D4 Subs Bnib
mm0142
CEO
I have 2 09 model RE *** D4 12" subs .They are still in the double sub box from RE .Flat wound voice coils and larger magnet for better cooling than the previous RE SE models . Higher RMS also . I was going to use them but got a 18" Nightshade and going with it instead . Looking to get $380pr shipped local $350pickup
not much for trades im trying to get a saz3000d ofrlarger with cash on my end for the deal i have a 18" nightshade inthe mail right now i want to use . if i cant sale these or get the amp im probably gonna use these and sale the nightshade for $500 it has the new alumuinum pole vent they came out with this week it should be here by friday also .
pm's answered
heres the specs also .
12"
Mounting Depth - 6.5"
Mounting Hole Diameter - 11"
Overall Diameter - 12.5"
Bolt Hole Circle - 11.75"
Motor Width - 6.25"
Motor Depth - 3.25"
Basket Depth - 3.25"
Displacement - 0.15 cu. ft.
Weight - 21 lbs
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
nice subs.. i didn't know this was a production model... hmm.. wish i didn't have these 2 pap wmd2 12's still. or this might fit my smaller install! bump
pm's sent and answered $380 is the price shipped i need the cash right now thats alot cheaper then you will find them anywhere bnib. i heard them at the local dealer for re . they sounded about the same to me a little tighter bass but not much just handle more power and run alot cooler .
I had sent in old se's under warranty andtghe dealer was out of stock on the se's so upgraded me to the ***'s for free.
the sale on craigslist emnded up being a nigerian scammer ****it . still for sale people .
if anyone has an 18" d2 nightshade im up for a trade .
mm0142
CEO
mm0142
Waco, Tx
mm0142
