SOLD FS: 2 MTX Thunder 8000 10''. Pioneer 10'', Batt Term, Spkr Wire, Helmet....
Computer is messed up and every other button I hit deletes my info so I am gonna make this short and simple. I will answer Pm's as quickly as possible and reply to the thread in the same matter.
1. 2 MTX Thunder 8000 Single 4 Ohm subs.
Perfect shape cosmetically, had them running off a Kicker KX 600.1 and they slammed, the functionality on the subs is as follows, the left woofer needs the negative tinsel lead soldered to the terminal. The right woofer is missing the terminal and needs both wires soldered. The guy I purchased them from had them fixed to where they would never come undone again and they would handle all the power you threw at them it just looked rigged how he done it so I undone the wires and was going to fix them myself. However I 100% guarantee both the woofers to work and not to be D.O.A $65 Shipped on the left woofer and $55 Shipped on the right.
Right Woofer
Left Woofer with less to fix
2. Pioneer 10'' Single 4 Ohm, 500 watts max, good little cheap woofer $35 Shipped
3. Wal-Mart Speaker Wire 40 Ft 18 Ga. *New* $10 Shipped.
4. Tsunami Gold Plated Positive Batt. Terminal, 2 8 Ga. Inputs, and 2 4 Ga. Inputs. *Used* $8 Shipped.
5. AFX Helmet, Blue and Black. Size XXXL but it's not huge. *Used* $30 Shipped.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
858
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
blaze383
Banned
blaze383
Marion, North Carolina
blaze383
