FS 2/0 rolls Large agm batts misc wire cables speakers
12voltz+-
lorain OH
1. Product:
Alllll right kinda gonna combined a few things to one thread since its all in the same section.
Locals are welcome to meet up to get any of it cheaper of course package deal on batts if you get more then 1
2. Specs:
First i have 4 rolls of diyma 2/0 power cable in blue and in black (2 of each)
2 used 5.25'' jbl gti mkii mid/woofer 2 ohm woofers and 2 ohm ea
Next i have 14 alpha cell 100 ah batts bnib
Model: 195 GXL
Warranty: 4 years
Service Life: Extended
Runtime (minutes): 196
VRLA Battery Type: Gel Silver Alloy
Heat Resistant: Extreme
Hydrogen Emission: Low
Terminals: Threaded insert 1/4” - 20 UNC
Cells Per Unit: 6
Voltage Per Unit: 12.8
Conductance Value: 1100
Max. Discharge Current (A): 900
Short Circuit Current (A): 2600
10 Second Volts @ 100A: 11.3
Ohms Impedance 60Hz: 0.0050
Capacity at 20hrs (to 1.75VPC): 100AH
BCI Group Size: 31
Weight (lb/kg): 67/30.5
Dimensions H x W x D (in/mm): 8.5 x 13.4 x 6.8 / 215 x 341 x 173
4- bundles of kicker 16g speaker wire very nice oversized flexible silver tinned ocf 40 ft each bundle
3- femal flush mount 3.5mm aux audio input jacks with 3.5 to 3.5mm cable make your install nice and clean get rid of hangin cable and get them outta the glove box ect lol
3- Isimple ipod cable there have the docking cable 30 pin ipod cable to rca audio R & L as well as a Video. Also has charging input hook it right up to you car and it will charge your ipod
1 set of 5x7 adapters to 5.25 or 4x6 and 1 set of 6x9 adapters to 6.5'' and tweeter
lots of grills 1 set of jbl gto 6.5'' grills 1 set of rockford 6.5'' grills 1 set of diamond audio 6.5'' grills 2 set of rockford 4'' grills and 1 set of jbl 5.25'' grills as well as a 1'' 6.5'' spacer ring.
Single d6 6.5'' midbass woofer
lastly the box or wire lol its starting to over flow! its the scrap bin. so if you need small to mediumk length of 8g 4g 0g cca ofc let me know as well and some short length of speaker wire
3. Description/Condition:
all 4 rolls are bnib
used over all good condition hooked them up still sound real good
all batteries are bnib beside one pulled out for pics
all bundles are new not used
all 3 and new
all 3 are new
both sets are new
all sets are new
new but dirty just needs whipped down make a nice center ch or test speaker idk lol
wire some used some new just short or scrap ends
4. Price: :
80$ shipped per spool
70$ shipped for the pair
180$ per battery locals only atm (north east ohio)
15$ shipped kicker speaker wire
15$ shipped flush mount 3.5
15$ shipped each ipod cable
10$ shipped each set of adapters
10$ shipped each setof grills
15$ shipped for lil d6 6.5
wire we will make cheap if you need a piece ill see if i have it give you what style of wire it is and shipping + a few bucks in pocket im happy lol
5. Pictures:
OBO
i have plenty of 4-5ft length of knu cca offer up for how many short runs like that you want i have blue black and red think i might have one 10-12ft run in black some of these fo have ring terminals cripped on already as well
Is it 4 or 0 gauge? Because I'll make an offer on most of it, I'm just not sure what size it is. lol
8 4 0 all of the above lol some ofc some cca some kicker knu stinger db link ixos bullz qpower mobile spec scoche efc and more!
Do you have three 4-5 ft. lengths of 4 or 0 gauge, and a 10-12 ft. length of 0 gauge? All Knukonceptz, please. if longer than 4-5 ft. that's fine
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
936
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
12voltz+-
12voltz+-
lorain OH
Fi-Chipmunk
SlugButter
    May 4, 2024
slater
    May 2, 2024
