Sold FS: 12" TC SOUNDS TC3000 DUAL 2 ohm very low use
newtitan
Ive had this sitting around hoping I could manufacture a box for the truck, but its about 1" too deep , due to the high roll surround
looks awesome, sounds awesome, but too deep
$325 shipped or trades, its VERY heavy, so shipping is most of this cost
TRADES IM LOOKING FOR
*peerless hds tweeters or some BG neo8's
*logitech z5500 amp and controller (I want to try some cap mods on one and dont need the satellites)
*pc2 9200 ocz reaper ram kit 2gb kit
*750gb sata seagate or WD HDD (REALLY need these) no bad sectors though
*kinetik 2400 battery new
*makita 18V lithium battery charger/battery set
* nice two channel HT amplifier, or 5.1 (like a panasonic XR55 or XR57) with a sub output
*250W to 500W plate amp bash is fine
*tube headphone amplifier , like a little dot IV
*beyma 8mi drivers used or new is fine
*nice 3000W amp @ 1ohm mono
Ill have pics in a few, its looks new though
my references, well some of them
http://www.diymobileaudio.com/forum/...ad.php?t=21113
http://www.diymobileaudio.com/forum/...ead.php?t=9628
http://www.diymobileaudio.com/forum/...ad.php?t=16217
http://www.diymobileaudio.com/forum/...ad.php?t=16079
http://www.diymobileaudio.com/forum/...ad.php?t=13043
http://www.diymobileaudio.com/forum/...ad.php?t=11721
http://www.diymobileaudio.com/forum/...ead.php?t=8563
http://www.diymobileaudio.com/forum/...ead.php?t=7376
http://www.diymobileaudio.com/forum/...ead.php?t=6358
http://www.diymobileaudio.com/forum/...ead.php?t=3152
http://www.diymobileaudio.com/forum/...ad.php?t=21982
http://www.caraudio.com/forum/showthread.php?t=170338
http://www.caraudio.com/forum/showthread.php?t=160744
http://www.caraudio.com/forum/showthread.php?t=104632
lets make a deal folks
added some leap box sizes and graphs so folsk can see that these only need VERY SMALL BOXES
and the specs off the TC legacy spreadsheet
Fixed DVC 12"
Qms 6.77
Res Ω 4.24
BL ™ 22.60
Mms (grams) 330.00
Cms µN/M 131.00
Sd (m^2) 0.0490
Lp (mH)
Ls (mH)
Rp Ω
Constants
c (m/s) 341.00
d (kg/m³ 1.20
K 9.64E-10
Calculated
Vas (liters) 43.89
Fs (Hz) 24.21
Qes 0.417
Qts 0.392
n0 1.44E-03
SPL (dB) 83.58
Specs:
• 160 Newtons2/watt Motor Force
• 1000 Watts Continuous Power
• 3" Anodized Aluminum Voice Coil
• Single Dish Titanium Cone
• High Excursion Tall NBR Surround
• 215 Ounce Magnet Structure
• Anti Flux Modulation Shorting Ring
• 30mm XMax
• 10" Diameter Suspension System
• Custom Cast Aluminum Frame
• Quick-Detach Top Assembly
TS Specs
12" TC-3000 QVC 2
Qts 0.306
Qes 0.323
Qms 5.97
Fs 24hz
Res 4.63Ω
Ls 8.85mH
Lp 19.25mH
Rp 25.95Ω
Dia 240mm
Vas 43.9l
mms 339g
cms 129um/N
bl 27.1T*m
Spl 84.7dB
used em maybe two weeks
Too bad... I'd so trade my 3 TC9 12s for these. Would go perfect with 2 Ampman Revos. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
All I've got that I'm not using is a cosmetically-rough PQ20. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I just got rid of all my old a/d/s amps I couldnt take that turn off noise lol
who would have thought getting a nice 4 channel would be that hard
guess not a ton of tc fans huh?
newtitan
newtitan
CALI
newtitan
    Jun 20, 2026
    Jun 20, 2026
