Sold Forsale RD 10s and matching amp
dumple
What's in your trunk?
pictures first
will entertain trades now guys
sub specs
500 watts rms dual 4 ohm mounting depth i do not know it say 8 inchs or less
10" D4
FS
33.17 HZ
RE
3.4 OHM
QMS
5.23
QES
0.25
QTS
0.237
RMS
7.12
CMS
1.2899 MM/N
MMS
178.44 G
BL
22.6 TM
SPL@1W
87.23 DB
VAS
20.06 L
XMAX
13 MM
XCOIL
36 MM
amp specs
RMS power, 1 ohm mono 1050w x 1ch RMS power, 2 ohm mono 600w x 1ch Signal to Noise Ratio >100dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
125 per sub
215 for the amp
pm me for more pictures or other inquires
dumple
dumple
Philly
dumple
