Ford Expedition 4 15 RE SE
box was tuned for 60hz ...... tested multiple time with different setups and found that 60hz is the vehicles freq. Sounds great daily and smashes the (2) 12" classes at most comps in a huge truck
What did it do on a realistic daily tune i.e. ~34-36hz?
im not going to put the full 1100 to each se. im going to have the gains set so each is only getting around 750ish. i have a question about that. when im doing the gain, will it distrort at 750ish if thats all the subs want to handle, or at the full 1100 potential? ie how do i make sure not to give them more than 750ish watts a peice
just keep the bass boost/loudness off on the deck and amp, only use the bass,mid,teb setting to adjust bass which will give you cleaner signal to the amp inturn can turn up the gain and not blow u're subs, 90% of why subs blow is caused by clipping, which is distorted signal that just gets amplified
Hello people...First time on this forumn...That 149.3 at 60Hz was in my truck...The box I use is the specially made one for the mojo 12's. 1 inch MDF. As a daily driver i have had no issue with bass dropping or anything. It does stay constant. Depending on money I will be getting another 4kw. One to each sub. So yes a 150 is very possible and I WILL be hittin it before the season is out.
UPDATE! another update in a week or two also
taintedplay
taintedplay
dallas
taintedplay
