//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifActually, excessive mileage with improper tire pressure blow speakers. Your friend should watch his psi more closely on road trips.
The problem with almost all the analogies so far is that they are incorrect, including this one.Many of the previous analogies are correct, like the one about jumping off of a skyscraper - that's not what kills you, the impact does.
No, let's get all technical, for that is where the answers are found. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifLet's not get all technical.
But to get real technical its actually the heat from the power and not the power itself. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifAlso, people should notice that everyone who has supported this concept (re: clipping doesn't blow speakers) will likely still agree with me that the input sensitivity should be matched to the preout voltage of your HU (and not with a DMM either....please stop using that method). This is simply a clarification of what clipping really is and a necessary explanation of what damages a driver....power, and power alone.
Actually, its the molecular degradation from the heat, not the heat itself, that causes the coil to melt and the circuit to fail.But to get real technical its actually the heat from the power and not the power itself. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
You're really saying the same thing if we assume a fixed coil resistance. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifBut to get real technical its actually the heat from the power and not the power itself. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
And yes I know you cant have power without heat. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Mike Edgar (goes by 95Honda on a few forums) did a test a while back that showed exactly what you're looking for. I'll see if The Wayback Machine has it....But has anyone, real world, tested if clipping will produce heat faster than unclipped power?
You may be surprised.
I know I was just teasing. It wasnt to be taken seriously. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYou're really saying the same thing if we assume a fixed coil resistance. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That would be great. It would be nice to see someone else's findings on this.Mike Edgar (goes by 95Honda on a few forums) did a test a while back that showed exactly what you're looking for. I'll see if The Wayback Machine has it....
I never said heat was created by power. I said you cant have power without heat. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifActually, its the molecular degradation from the heat, not the heat itself, that causes the coil to melt and the circuit to fail.
And the heat is caused by friction, not from the power itself.
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You can if you have no friction. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Or, more realistically, the amount of friction dictates heat generated just as much as the power present. In terms of this discussion, the resistance of the coil affects it just as much as the amount of current passing through this coil.I never said heat was created by power. I said you cant have power without heat. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Real world apps, power will always have friction. We dont exist in a vacuum. Nor did I say power is the only cause of heat. But thank you for clarifying for the noobs. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifYou can if you have no friction. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Or, more realistically, the amount of friction dictates heat generated just as much as the power present. In terms of this discussion, the resistance of the coil affects it just as much as the amount of current passing through this coil.
If we are gonna get all nit picky technical. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
