Focal ES 165 KX2 speaker
  • 4
Hello,
I have two set of Focal ES165 KX2 speakers, I will run 4 channel amp for front set. I have other amp but only two channel. Can I run two channel amp to other set of ES165 KX2 for rear? On passive x over that came with speakers have 4 channel input. Please advise.
Here is the link of speaker ES 165 KX2 | Focal America
Thank you,
Is there any reason you want to keep rears? Are you planning on time aligning and using your DSP for anything that would require each speaker having a dedicated channel?
Since I already bought rear speakers and just want to use it. I have Helix .2 DSP but only 8 channel and that would do front 2 tweeters, 2 mid and sub so it will take 6 channel. I am just going to put the rear in and use it when someone sit on the back seat. But when I tune DSP I will turn off rear channel.
with a properly done front stage, you can be heard a whole football field away loud and clear. There's no reason passengers a few feet away cant hear.
Hello,
Thank you,
Refer to page 14 of the user installation manual for instructions on powering the passive crossovers with 2 amplifier channels.
Yes, but since I spent $800 for that set, it would be nice to use it. If I knew that I don't need rear speaker so I would save $800. It is my bad.
Thank you. The information is not clear to me. As you can see from picture, left channel go into left input on passive x over but on the x over have a red sticker shown Bi Amp (input) and those are 4 channel input. So I don't know where to put one + and one - to those 4 input. Please see pics below.
Please advise.
Thank you. The information is not clear to me. As you can see from picture, left channel go into left input on passive x over but on the x over have a red sticker shown Bi Amp (input) and those are 4 channel input. So I don't know where to put one + and one - to those 4 input. Please see pics below.Please advise.
Use a small piece of wire, your speaker wire is good, to bridge between + and + and another wire to bridge between - and -. Then it doesn't matter which pair of terminals you connect the amplifier wires to as both input terminals will be sharing the power.
Thank you so much. Now I can use all of my amps and all Helix .2 DSP channel.
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
$2500usd package Shipping and PayPal fees extra I have a nice sub and 3way system available. All BNIB If you need more than one sub or rears...
I sure was eyeballing that Joker!! 👀 👀 :poop:! Nice amp!!
Excellent set of speakers if they're in good condition. I ran the home audio version of that midbass driver for a while. Still have them in my...
13
Tony1234
Tony1234
rancho cucamonga, ca
Tony1234
