Foam weather stripping or neoprene rubber stripping "Seal blow thru enclosure "
  • 4
View attachment 26557275View attachment 26557275New 13 layer birch Box is done for bed blow thru .
Built the box and a trim ring encasement from 2 by to not only secure the box flush to the accordian boot but to secure box tight to the bed wall.
My idea was to weather strip 1" or 2"around the 2.5" trim ring i made so it fills in any small voids as we all know some accordian boot and cab designs arent flat as its pulled tight with some small lag bolts I'm going to drill out for.
What type of weather stripping is dense but won't end up brittle , I know It needs to be 1 -2" thick preferably as its gonna smash as I draw in on the Box trim ring .
This is for anyone who's played with a blow thru set up
My box is inset into cab flush with interior back panel.
Have zero experience with that but I'd do a couple tubes of windshield urethane. //content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
Thanks it has a tune around f3 at 34hz
6ft total 1.25per sub.
It's also built to enclose other driver options other then the sa 10s.
I can actually run sundown x 10s or xfls..maybe more .
I just got it in the cab and secured with 1"x1" neoprene weather stripping and Four 1/2" lag bolts drawing it sealed to the cab.
I'm just debating on drivers at this point initially sa 10s just wondering if I should shoot for AB Xfls
Im close to Considering sound deadening back side of interior door panels for Experimental purposes on top of the fact the inner and outer skins are already done along with roof back cab wall , pillars, and floor board.
I should see some decent DB'S the box is spot on !
Wolfram 3000.1
Alternator upgrade and two yellow tops in bed
Pioneer nex HU
Hertz mpk components
SOUNDSTREAM TN 4.900
Kilmat 80mil deadener through out cab some areas double layered ....been at this off and on since roughly December ambition will drive you to actually continue projects in the dead of winter .
On top of the Sound build I threw in new carpet and headliner.
3/4 Static drop kit 20" wheels and new lights all 4 corners
Next is a second set of 3 way components and a custom center council. Possibly iPad install.
Mineral wool is another nice dammned good insulation fire proof. Prob same as the Rock wool mentioned. that stuff will last forever
14
Things happen. It will be a story you can tell him and laugh about when he gets older. Kids around speakers = damaged speakers. I had a yard...
Androidaaron36
Belleville mi
THATpurpleKUSH
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
