flexseal in sealed box?
I was going to build my box today and was wondering if anyone had tried flexseal inside on the seams. I haven't worked with fiberglass before and didn't want to make a mess .
any thoughts ?
thanks.
mike
fiberglass is better. it seals and makes the box alittle stronger as well because it hardens. But honesty with a sealed box flex seal should be fine
yea it's a small 1.5 cube box with single 12" . so if you did the fiberglass would you use just the resin and spread it or do you use the fiberglass cloth then resin over that. I figure I might as well learn, I know a lot about everything else so I guess i'll give it a shot.
jeepguylv
jeepguylv
las vegas, nv
mlstrass
