lol thats funny //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif; it would swell up like a spongesoak the mdf in water
Just curious. I mean I see mention of 32.5 Hz, which is a pretty accurate number.with a 4-5 inch radius its really not to much different for tuning purposes.
When doing port calculations, neglect the flared portion...so port area is the same, it's just a little bit shorter so your tuning will raise...which means you'll need to compensate by adding a few inches to the length.Just curious. I mean I see mention of 32.5 Hz, which is a pretty accurate number.
FYI ... As an example, that curved section with a 4" radius curve and a height of 12" (using the box picture in OP's original post) adds 41.2 cubic inches to the port's volume. (Same but with a 5" radius adds 64.4 cubic inches).
Seems like a lot to me.
I'm not even sure how curves vs square corners affect tuning. Maybe the fact that this is a curved section negates the added port volume?
Ports have specific height & width (aka area) and depth (the part of the port that is typically inside the box), no? That's volume, no? If volume doesn't matter, why not just leave off the part of the port that's inside the box?When doing port calculations, neglect the flared portion...so port area is the same, it's just a little bit shorter so your tuning will raise...which means you'll need to compensate by adding a few inches to the length.
The flare will also cut a bit off of your airspace, so you may have to adjust your dimensions and port length when adding a kerf to a design..
And port volume has nothing to do with tuning, fyi
I meant when calculating the tuning of an enclosure you need 3 things:Ports have specific height & width (aka area) and depth (the part of the port that is typically inside the box), no? That's volume, no? If volume doesn't matter, why not just leave off the part of the port that's inside the box?
The title of his movie is: "Men who stare at MDF!" //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifi thought all you had to do was look at the mdf thumpper...!?!?
Haha!The title of his movie is: "Men who stare at MDF!" //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
hahaha...then once it dries you'll have 2" mdf for the price of 3/4...//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gifsoak the mdf in water
