Fixing coil rub
  • 5
Dirtrider4eva
√\_The CaUsE__
I have a sub. It has a tight gap, and an 8 layer coil, well, it developed some nice rub. Any way how to fix it?
I've heard anything from popping the dust cap, realligning coil with shims, and re surrounding,
But it has some stiff spiders. So wouldn't that affect it more
Oh yeeaa, DENIED
---------- Post added at 01:18 PM ---------- Previous post was at 01:18 PM ----------
put a stick/piece of cardboard inbetween the part rubbing, also maybe some vaseline even though youd have to reapply weekly. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well once they're Hooked up and running it isn't that noticeable at all,
Might just deal with it till spring
Is there any last ditch effort to try and recenter it before a recone?'
Well once they're Hooked up and running it isn't that noticeable at all, Might just deal with it till spring
well if it wasn't rubbing to begin with but is now the coil is damaged and will probably die one day when your pounding on it hard.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
493
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
Dirtrider4eva
√\_The CaUsE__
Dirtrider4eva
Milwaukee, WI
Dirtrider4eva
    May 18, 2024
    May 18, 2024
