Fitting ring terminal
Nightskye
A 1/0 gauge ring terminal will not seem to fit the ring terminal port on a Knuconceptz battery terminal. The 1/0 port is already in use.
How can I fit the 1/0 ring terminal on the port? Cut it a bit? Bend it? Suggestions?
Thanks //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Doh, that might help.
I'm just trying to fit the crimp ring terminal below into that groove that the terminal screw sits on top of the battery terminal. The ring terminal is a bit too large and won't fit the groove without some modification.
It's not the length of the bolt, but the width of the ring terminal surface.
Yeah, think I'll just take my dremel and grind it down.
Hopefully I can keep close to the original shape so it won't look too bad under the hood.
Nightskye
Nightskye
East Bumfvck
Nightskye
