First time help
KILL3RCOOP3R
22
US
Here is what I have
Car : 2013 Honda civic baseline model
Headunit : Pioneer 5700bhs
Speakers: 4x pioneer ts-a1685r 60w nom
Sub: x2 pioneer 12" ts-w3003D4 600w nom dvc 4ohms
http://www.pioneerelectronics.com/PUSA/Car/Subwoofers/Champion+Series+PRO/TS-W
Sub box: sound ordinance bb122 175v
Amp 1": Pioneer a6604 ( for speakers)
GM-A6604 - 4-Channel Bridgeable Amplifier | Pioneer Electronics USA
Amp 2: Pioneer d9601 (for both subs)
Amp kit 1: efx 142PA8BX 8AWG
Amp kit 2: efx 142PA4BX 4AWG
Circuit breaker t spec 180amp
Speaker wire : I have 40ft of 14g ( for the speakers)
Stinger PRO Series Speaker Wire (14 Gauge) Priced per foot at Crutchfield.com
and 10ft of the 12g ( was told needed for the amp)
T-Spec 12-gauge Speaker Wire Black/white jacket — priced per foot at Crutchfield.com
I hope all that above helps. Ok so I installed speakers and head unit less then a year ago. Everything else will be install which I though last week but ran into a few more more complications I was hoping to help get solved here. ( first time some where else, which is why im stuck now) so thanks in advance
Let's start with cables I was going to run both power cables from the battery which is why I have two Amp kits. Instead a multi Amp kit. But been reading only need one is needed. So should I get a bigger wire Guage like 1/0 and power distribution box. And should I get 17 ft since that what come in the amp kits. Do I need one fuse holder or three ? And location where do I put them. My theory is to put one before power distribution box which I have circuit breaker instead and use the oneshe that came with the amp kit close to the amp after power distribution box?
Will 40 ft be enough speaker wire or should I buy more before I start and how much more?
Do I need this ?
EFX 9-Wire Ultra Flex Speaker Wire (20 feet) All-in-one cable for speaker and amp installation at Crutchfield.com
The amp for my speakers has two rca inputs can I put rca cable from head unit front to one channel and head unit rear to another channel on the same Amp?
I know I need power distribution box and at least one more power/ ground cable will there be anything else I didn't mention that I may need to start I rather have it and not need it the not have it and need it.
Sent from my SM-N920T using Tapatalk
You should get a 1/0 Gauge wire from the battery to a power distribution block, and run power wires to the amps from there, Only one fuse will be necessary under the hood near the battery, If you go to a local audio install shop that isn't Best Buy (seriously DO NOT go to Best Buy), you should be able to get wire by the foot, just measure how much you will need to get to the truck or wherever you and puting the distribution block. And don't buy the 9 wire ultra flex, it would be useless to you. You want to put the headunit front speakers to channels 1 & 2 and rear to 3 & 4.
KILL3RCOOP3R
KILL3RCOOP3R
US
dubstepper1000
