First sub build question.
  • 1
therealjroc
Ok. So I want to build a custom sub box for my Colorado Extended Cab. This is my first box so few questions.
1. I want to build a box to the sub specs then have a large face inside. Is there anything special I need to do or as long as the inner box is solid the rest will be fine?
2. I'm thinking about rounding the edges, filling the gaps, and covering it in black plastidip to my the plastidipped accessories in my car. Is there any issue with plastidipping instead of carpet?
I'll post pictures of the space it's going into. (replacing Infinity basslink) and a sketch or two of what i'm thinking about. Not sure If I want to surface mount the amps or hide flush mount. Again, this is my first build, so if you see anything that might be an issue let me know! Thanks!
View attachment 26540348View attachment 26540349View attachment 26540350
Alright man .that is what i have been leaning torwards .i appreciatte your opinion . I feel like the 18s will be great for a daily without having...
267
433
537
therealjroc
therealjroc
Clarkston, GA
therealjroc
    May 18, 2024
    May 18, 2024
