First grade question
99durango5.9L
NY
the amp i bought calls for 2 gauge wires.....right now i have a 4 gauge wiring kit....can i use that....or would i have to buy a different kit.....what would happen....//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
..... Can u use it? yes.
if ur amp REQUIRES that gauge, it could be different, but assuming ur asking the question its fine.
....if i run the 4 gauge for a little bit whats going to happen the amp wont run as efficient as it could?.....im going to get a 2 gauge soon but i want to hook it up now...
more resistance = less power
alright so it just runs at less power....but it can't hurt the amp or sub right?
how much power? Anything under 1000w should be fine with 4 gauge
600w @ 4ohms, 800w @ 2ohms, 1200w at 1ohm....im hooking it up to a cadence dvc 2ohm sub....3000w peak....1500 rms....
4 awg should be fine. However, I vote that you just get a 1/0 gauge wiring kit and trim the part down that has to be inserted into the 2 awg amp inputs. Then you won't have to worry about anything, and if you want to upgrade to more power later you don't have to get new wiring.
99durango5.9L
99durango5.9L
NY
Hintzyboy
