mikey7182
I'll be running one set of Pro60s off an Alpine MRV-F545. The birth sheet on the amp states ~164w per channel into 4 ohms at 14V. Now in a perfect world I could assume that halving the resistance will double the output, so using that, the 3 ohm mids should see ~246w each at full gain. This may be a tad too much for them as I have heard the 200w arena is where they like to play. Maybe not. My main question is the tweeters... at 8 ohms, they'll still be seeing 82w at full gain. This seems like a bit much as well. I can always set the gains- just curious how many watts (roughly) I should run to the highs.
Another thing is xover points- I have a 9887 HU and will be running them actively through that. Should I leave the amps at full range or set their xovers/filters to the same frequencies as on the deck as 'backup'? That may sound strange but I've had issues in the past where I set a HPF on the deck and the amp on full range and it seemed to want to respond to frequencies lower and quite a bit louder than what I set the HPF at on the deck. Maybe I didn't slope them steep enough- who knows.
What points have people set the xovers at running the bostons actively? I've thought about ~3.5khz... just not sure about the slopes, etc. I was thinking crossing off the mids at 3khz@-12db/oct and the tweeters in at 3.5khz@-12db/oct.
Sound okay? Obviously it is all in how it sounds to me- I just don't want a huge spike in sound around 3200hz and this is my first time running components active. Any suggestions would be appreciated.
Mike
Mike
