finishing up my box....need advice
302yota
well i've got all of my sides cut out (except for my top plate)...and all of my cuts are no more than around 1/16th of an inch (first time with a circular saw).....but when assembling all the pieces, and/or screwing them together...is there anything i need to know about "predrilling, filling, sealing, bracing, or anything else", what are the best ways to do this, if all of that is necessary.
Go to Home Depot, and pick up a box of SPAX self tapping wood screws. Will save you a TON of time.
And put the side pieces up first, NOT the front or the back. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hope that helps.
so ur saying, use the bottom to assemble the sides to, and then procede to the front and back sides, and last put the top on....if so how will i know that the port is sealed with the bottom of the top plate...btw i have liquid nails, and some silicone will that work.....how long will those screws need to be with 3/4in mdf board?? will the wood not split using them?
i trust you ls2, and i'm gonna go with no pre-drilling, only because i'm to lazy to do that....what about the length of those screws?
1"1/4" - 2" would work. Too much longer and it will be a PIA.
I would suggest in buying like 10 long clamps //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif That's all I use, clamps and glue.
Self-tapping wood screws, a good wood glue, clamps.
If you're carpeting the box, recess the side ~1/4", so that you have an inward fold to cut against, so the carpet gets a much better finish.
Ok. If you buy tweets they’ll come w their own inline crossovers. Youd connect the speaker wire to the crossover which then connects to the...
925
444
646
962
302yota
302yota
rockingham, NC
Ferendon
    May 31, 2024
    May 24, 2024
