Finding the right amp. JBL GT5-2402BR
tysonx
I guess this is the second part of my question.
By the end of the week I'll own a JBL GT5-2402BR
JBL
With the specs at:
3/4" medium-density fiberboard construction covered with carpet
Slipstream slot port
Impedance: 2-ohm
Recommended power: 200-550 watts RMS total (1,600 watts peak power)
Frequency response: 40-200 Hz
I'm looking into this amp here, KENWOOD KAC-7204 2 CHANNEL 1000 WATT
KENWOOD KAC-7204 2 CHANNEL 1000 WATT CAR AMPLIFIER - eBay (item 290437393815 end time May-30-10 12:33:33 PDT)
With specs at:
Amplifier Type Dual Channel
Channels 2-Channel
Bridgable Bridgable
RMS Power at 2 Ohms 250 W x 2
RMS Power at 4 Ohms 170 W x 2
Sensitivity: 90 dB
It looks like both operate at 2 Ohms, and the subwoofers around 250w RMS at 2 Ohms, while the amplifier is 250w at 2 Ohms. Is this a good match or is this amplifier overkill, do I even need 1000watts? Or am I completely misguided because I really don't know much.
If you can recommend an amp that will suite the subwoofers better. I would really appreciate it.
Thanks.
(Edit: By the way price range under $175)
Thanks.
I assume that a loaded enclosure acts as one unit and doesn't need two channels?
Also not looking for kenwood specific, but the amplifier you gave me will work.
Thanks.I assume that a loaded enclosure acts as one unit and doesn't need two channels?
They make them pre-loaded to a final load of 2 ohms. Which they handle 550 rms
That amp puts out a CEA approved 500 rms at 2 ohms, which is good for that price.
Enjoy.
tysonx
tysonx
Houston, TX
Vossy
